RCU Forums - View Single Post - Official HPI MT2 Thread
Old 02-22-2007 | 05:58 AM
  #13354
arapoda
Default RE: Official HPI MT2 Thread
ORIGINAL: murawskiallen
the 18 cv-rx comes with a really good air filter so you dont need a different one, and that one that you posted will not fit cause the carb inlet has the same size as a big block.. yes the stock manifold will work on this engine and yes that glow plug igniter will work, they are universal
ORIGINAL: arapoda
Does anyone here run the O.S .18 CV RX engine? If so, I have a few questions. What is the width of the carb, and what air filter do you recommend? I've got this one, but will it fit on to the O.S?
http://www.hpieurope.com/piw.php?lang=en&partNo=72175
Also, will the stock MT2 pipe and manifold work okay with this engine? I will order a tuned pipe soon, but for now I'll have to make do with the stock pipe.
And finally - Will the purple HPI glow plug igniter work with the O.S? I'm assuming they are pretty much universal.
Thanks.
Thanks for that! I only ask because I'm about to order the O.S engine (and lots of other bits to go with the MT2) as I am now VERY BORED with the T-15 engine.
