Dominator assembly help
RVD the photo that Jack posted above is what you wanna do. Of the three Preditors that I have assembled all had the aileron torque rods too far apart and would conflict with the wing bolt block in the 'U' or "V' notch between the blocks. The average distance between them has been 3/4 to an inch apart.
The solution if you plan to use the original torque rods is to cut the notch in between the two rods and simply slide them closer togeather in the middle before you install the ailerons. If you keep them no more than about 3/8" apart it will not be neccessary to releive so much from the bolt block. Of course you do have to make another hole in the aileron for the other end of the rod that you moved inward.
John
