Just browse thru the manual posted above and see if there is anything mentioned that you can't do or don't have.
You can NEVER have too much fuel tubing laying around either. Looks like the surfaces are pre-hinged so that's a plus. Make sure you check them well, don't trust the factory. They've been known to sleep through that task before.
You can use alum spinner if you want, up to you. I never have. But I'm cheap.
