RCU Forums - View Single Post - Getting back into flying...need some help
Old 02-22-2007 | 09:36 AM
Pete1burn
Default RE: Getting back into flying...need some help
Or, don't use the ailerons at first. Get used to turning the plane with the rudder only. That will also train you how to fly a four channel plane with the rudder when you do move to them.
Then when you're comfortable using the rudder to turn, you can try some slight stick movements with ailerons.
Trust me, it's worth learning 4 channels if you plan on sticking with the hobby.
