RCU Forums - View Single Post - first timer covering
Old 02-22-2007 | 10:06 AM
venom290's Avatar
venom290
Default RE: first timer covering
Thats correct, 6th or 7th plane, but whos counting. The wings are foam and the kit calls for .049 to .079 engine. .10, .15 mabey. May go a little bigger.. I did build a little stonger for that reason. (extra braceing, longer, stiffer main spar in the wing, etc). need to go to lhs to pick up some flex control cable for the ailerons. Had a plastic cable in kit, didn't like the looks of it.
venom
ID:	627174   Click image for larger version
