RE: FOX Composites HAWK Build thread
Ok 7 hours today...
Post 1
(pic 1) Elevator servo fitted and tested with linkage
(pic 2) Had to file some 5 mm off the bottom edge of the elevator pivot unit. On full up it touched the bypass duct (test fitted)
Fox Comp have been informed. Minor problem really.
(pic3) Test fitting of Tail plane halves with fin off to check for clear movement.
(pic4) A small section of the underside of the fin needs to be cut away to clear elevator pushrod.
(pic5) shows cut away.
