RCU Forums - View Single Post - problem tuning
Old 02-22-2007 | 11:29 AM
rushevoross
Default RE: problem tuning
the idleing screw is the problem, this is located under/next to the air filter, and wen u take the filter out u should see a 1mm opening in the carb, if not use the adjustments on your transmitter, the one that says throttle and tweak until 1mm opening in the carb
