RE: Best type of hinge?
I would go with the nylon hinges with the steel pin and use the hinge glue as suggested. I also go back and pin the hinges using round tooth picks and wood glue. Then go back and dremel the tooth picks flush with the surface and then seal the ends with a drop of CA. I have never had a failure doing this. There are a few rules to installing CA hinges properly and if not followed, the result is either you don't get the proper movement of the hinge or, it will crack and then break on you. [8D]
