RCU Forums - View Single Post - edge 540 roles left with up elev.
Old 02-15-2002 | 07:05 PM
Scorpionjack's Avatar
Scorpionjack
Default edge 540 roles left with up elev.
Yepper definately sounds like Elevator transition isn't linear. Here is a little trick for split elevators. Take a straight piece of piano wire and mount it so it angles from the Elevator to behind the Rudder. Do the same thing and line-up the ends of the piano wire. Now turn on the radio and ease the elevator up and Down Full deflection and see if they have they exact movement.
Lay odds this is where your problem is.
