RCU Forums - View Single Post - FOX COMPOSITES Bae HAWK, Build thread
Old 02-22-2007 | 04:39 PM
GrayUK's Avatar
GrayUK
Default RE: FOX Composites HAWK Build thread
Ok chaps here we go again
Tonight was a bit slow due to family but.
I started by fitting the engine hatch cover
Pic 1 Marking out the slot for the slide catches.
Pic 2 Underside shows the cut-out 30mm long 10 mm from edge and 3mm wide. The hatch is fitted to mark the balsa
Pic 3 shows the catches in place
Pic 4 Catch activated and the hatch in place, taken from underside
Pic 5 and 6 I decided to cut out the air scoops
Pic 7 and 8 shows the glass covered balsa fus strengtheners and radio rail glued in place with RC modellers glue.
More tomorrow.
ID:	627474   Click image for larger version
ID:	627475   Click image for larger version
ID:	627476   Click image for larger version
ID:	627477   Click image for larger version
ID:	627478   Click image for larger version
ID:	627479   Click image for larger version
ID:	627480   Click image for larger version
