RE: 3W
If you don't know the proper way to provide a lot of additional airflow to a gas engine mounted on a test stand you will destroy that engine in very short order. Very short! I know I'm not alone is suggesting that gas engines be broken in while in flight on the plane, not sitting motionless on the ground. Either on a stand or on a plane, static break in is a very bad thing to do.
