edge 540 roles left with up elev.
Roadrunner,
It may be an engine thrust problem. Full scale planes will also snap to the left when you add to much eleavator. The wing stops flying and engine torque takes over. In a full scale you stand on the right rudder to keep the plane from snaping to the left. In our models we generally build in some right thrust to get rid of this. It's worth a try add a few more degrees of right thrust.
