RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 02-22-2007 | 11:01 PM
  #600
crashcrash
Default RE: Wheeeeeeee.......... Blade CP!
Jeese...I hate crashing. Check your tail boom to see if you had a strike. Spindle may be bent downwards from the hard landing...you can fix that. I got the crystals on order as well as a fresh spindle and main rotor shaft for the CP. The servo should be here tomorrow and I'll get the CP back in the air and down the Pro for crystals. I'm not really interested in flying the Pro...I'm sticking with the CP till I get good at it. Thinking about buying my son a CX2 because it will be easier to learn and hopefully less expensive parts wise if he does have a mishap. He's 26...just married 1 year, and just bought his first home, so he can't afford the drain that learning a CP will cost. Maybe the CX2 will be more forgiving.
