RCU Forums - View Single Post - Walbro Carb question
Old 02-22-2007 | 11:08 PM
tim220225's Avatar
tim220225
Default RE: Walbro Carb question
Does it fire at all? If fuel is moving then it is pumping, at least somewhat. Are you sure all the screws are tight annd you have no air leaks? I would look for a cracked spacer block, etc. You say you checked the screen, did you make sure it was reassembled with the diaphragm and gasket in the right order?
