RCU Forums - View Single Post - Fuel tank
Thread: Fuel tank
Old 02-23-2007 | 01:20 AM
andrew66's Avatar
andrew66
Default RE: Fuel tank
if the tank is touching the former on the sides or top, then i would cut out a small section and put some foam there. this is to ensure that vibration from the engine doesnt eventually wear a hole in the side or top of the tank. in my first plane (LT-25) i only put foam (a thin sheet b/c of clearance issues) underneath the tank, and had no problems whatsoever.
