RE: RCM Eagle V
You can still get the plans from RCM
You can also get a laser cut kit of the V version from PRECISION CUT KITS.. it would be easy to modify this into a VI or VII version!
In the June issue or MAN there will be a contruction article for the Eagle VI and VII
I can tell you that the V version flys very well
The designer is a mechanical engineer who used this model to verify computations for CG
