RCU Forums - View Single Post - Walbro Carb question
Old 02-23-2007 | 12:24 PM
tim220225's Avatar
tim220225
Default RE: Walbro Carb question
The tank can be about anywhere as there is a pump. Not like a glow engine. Still think you have a leak somewhere or bad diaphragms somewhere. Does the engine have an external pulse line? A piece of tubing running off of a tap in the case or carb spacer block running to the carb plate? If so check that piece of tubing for a crack.
