RE: Larger wheels on a trainer - what effects?
I'd lean towards all 3 - if you do just the nose you're raising the angle of attack of the wing while on the ground and that could possible cause you land on the oversize nose wheel if you don't get good flair (which will happen while your learning landings).
Hogflyer
