RCU Forums - View Single Post - Thunder Tiger J3 CUB servo help
Old 02-23-2007 | 01:13 PM
NJ Georgee
Default RE: Thunder Tiger J3 CUB servo help
Hi,The plane is big its a 82" span piper cub. They want you to install 5 servos and use 4 channels two servos are on the wing for the flaps.Then they want you to put the outher 3 servos inside ,1 for throttle,1 for the elevators with both of them connected together and rudder on the last servo. what I want to know is would you connect the flap servos to the rudder channel so as you turn ,say right the left flap would go down?
or do you connect the flaps to work along with the elevator so as you elevator up the flaps go down and viser versa
