yeah thats the way i was going to do it but there were certain complications and i wasnt able to do it, and it doesnt make a difference on the temps by running 2 tanks its the same as running one tank and then filling it back up before it completely runs out..anyways i just got in from running it and it ran pretty well until my rear diff stripped, but that wasnt by fault of the dual tanks, and one of the bad things about the dual tanks is it increased the top weight and i have to put the body posts really high so the body could fit over the tank
ORIGINAL: mt2nitronut
if i may suggest i think you would have to run the top bigger tank feeding into stock position then from stock position to the motor,just a suggestion but cool
ORIGINAL: murawskiallen
here is where i am with the dual fuel tanks, i havent gotten a chance to try it out yet but i will soon..the big tank is 100cc and the other one is 75cc so ill be runnin 175cc, which should give me about 35 to 45 minutes of run time...tell me wat you guys think
