RCU Forums - View Single Post - good setup?
Thread: good setup?
Old 02-23-2007 | 06:32 PM
My Name Is Brad's Avatar
My Name Is Brad
Default RE: good setup?
ORIGINAL: alloutcustom
what have you used to get the best speed? i want to go 45mph, is this acheivable. the lower the wind then more rpm for the same amount of cells right?
sorry for all the questions, i guess im just not knowlegable enough to the point where i can be confident.[&o]
hahahahaha!!! sorry to break it to ya mike, but if you wanted to go 45 mph, you should of got a bigger hull. There is NO WAY your going to be in control of a 24 inch hull going 45 mph.
have you thought about hull reinforcement?? your going to need it.
also, what about trim tabs?? I'd order up a few sheets of sheet metal, your hull is going to look like a sailboat if you want your boat to be controlable.
not trying to bust your ego, I'm just being realalistic.
