RE: good setup?
Do larger trim plates aid in extending the length of the hull? If so, could you use this for control at faster speeds?
I've seen numerous posts on all the forums that state length of the hull is what determines the speed threshold and controllability. However, what you said about the footprint or "ride pad" dimensions seem to make more sense in determining speed threshold.
I guess you could always add balast to the bow to prevent blowover?
