RE: good setup?
well a canard is a good idea. But the problem with that is if you were to use a servo to change the pitch then it would be pointless because you wouldn't be able to adjust it fast enough to control your flip.
As for the turn fins. Most turn fins on a mono do not touch the water when you are going straight. So i don't think that they would help
