RCU Forums - View Single Post - How to remove flywheel from GST
Old 02-23-2007 | 10:47 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: How to remove flywheel from GST
Good call Blade!! The battery terminal puller works fantanstic!! I just took my nx76 out just to check this out and reset my gear mesh..It works flawlessly!!
Headrash...I would be careful about advising people to do dangerous things...The flywheel flying across the room like a bullet is a common occurance using that method(prying screw drivers). Now if you had advised him to put an old wash cloth over it(to control the flight of the flywheel) as he was prying, it would have been more sound advice. Not trying to be rude, I just kept reading this and it bugged me that this guy could have easily put his eye out when that flywheel shot up and dented his grill and one of those studs on the flywheel hit his eye. I thought long and hard how to tell you that, but I guess direct won out. Dont get me wrong..that flywheel does not always "POP" off like that but why risk it when there are better ways to do it. Being 16 does make you special in all your wisdom, just enough to get you into trouble. I do hope there are no hard feelings but I would be remiss, knowing that danger and not sharing with you, since it happened to me many years ago when I was working on a weed wacker and it "POPPED" loose and chipped my front tooth. Wanna see a picture of my chipped tooth?
I dont even know you so I am NOT trying to flame you, just trying help by sharing my experiences and keep the hobby safe.
BTW,,Expect to be corrected when you give advise like that...
