My question is I have methanol,nitro, and various octanes of fuel available but non of the mixes mentioned in the threads so how would you mix up a gallon to try remembering I will convert the figures to metric. to arrive at the mixes that have worked so well for you guys out there.
Probably neglected to show just how to mix a gallon of this fuel. Don't want to cloud the issue on your using metric figures to mix a US fluid gallon, so let's just use percentages mix rates , by volume, they will work for any volume you wish to brew. Gasoline 66.66%; Methanol 26.66 %; Lube oil 3.333%; 3.33% Nitromethane. Klotz states their oil will mix with both gasoline and methanol so it should word just fine.
Good luck.
