RE: first timer covering
Your balancing method is correct. I have a couple little planes like this with larger than recomended engines as well. Try to get your reciever battery in the fusalage behind the wing craddel. I can't see if your build has it closed or open there or not. Any way yes I did notice which decal you had bacwards, Old Glory.
