RCU Forums - View Single Post - How to remove flywheel from GST
Old 02-24-2007 | 08:40 AM
.46NitroAddict
Default RE: How to remove flywheel from GST
ORIGINAL: RGX Blade
a "Battery terminal Puller" there small can fit in a tool box and Inexpensive....most auto parts stores will carry these....for under 5 bucks.........
usinga pair of "Screwdrivers" yes you can take it off but there is a "Risk" in "Cracking" the block.
as i "Have Seen it Happen"......not something i would advise....it can be done though....
ORIGINAL: The Real Dogman
I dont even know you so I am NOT trying to flame you, just trying help by sharing my experiences and keep the hobby safe.
Good call Blade & TRD,
The other benefit in using a puller, when this kind of tight fit is encountered, is that there is no risk of damaging your bearings.
This is another real risk, if using the 2 screwdriver method, due to all the pressure being applied to the block & in turn the bearings, via the crank!
HeadRush ROB.21, Please take this as constructive & not destructive critisim!
Happy Nitro'n,
.46NitroAddict [>:]
