RCU Forums - View Single Post - Nitro Models Extra 330 90 - 63"
Old 02-24-2007 | 11:08 AM
rgdea
Default RE: Nitro Models Extra 330 90 - 63"
Guys,
I purchased the same plane and i was surprised by the quality of the plane. The plane does require for you to make some minor corrections and the instructions dont help to much, but with a little imagination you can figure it out. Im in the building process and like you said, the wing tube has a very tight fit in the wings. To fix this I sanded the inside of the wing and now the wing tube slides in and out without a problem (Be careful not to over do it ). I just finished mounting my two servos on the wings, and im moving forward to install the pull pull on the rudder. Could you guys post pictures of the elevator setup? Im not there yet, but want to get some ideas on how to set mine up.
