RCU Forums - View Single Post - Help installing a kill switch
Old 02-24-2007 | 02:04 PM
gfyss
My Feedback: (14)
Default Help installing a kill switch
Hi all,
I just finished building my first gasoline helicopter (Vario benzin trainer with a G23RC) and I had to pull the original kill switch (button) in order to install a stator gator sensor. I would really like to put one back on the model, but am not sure what I can get away with. It would be much easier to put a switch between the spark plug connector and the crank case, but everything I'm finding only references the magneto and the case. Is the voltage at the spark plug too high for a switch to work? Is there an easier solution? I can't be the first person to run into this problem.
Thoughts and / or suggestions are always appreciated!
Thanks!
