RCU Forums - View Single Post - Ts Oxalys build
Old 02-24-2007 | 02:15 PM
Rune
Default RE: Ts Oxalys build
working a bit more on the stab today!
mounted the adjusters and the thin rod that those are resting towards in the fuse!
the carbone plates that the adjusters are mounted one was not placed at the same spot in both stabs (see pics) and the spots on the fuse who show where to drill holes for the adjuster pins was on mine ca 5 mm wrong.
i also had to make the hole for the MK Bellcrank to be able to glue the adjuster pin into place, i dont have 1,2 m long arms to reach all the way back into the fuse!
Its really starting to look like a plane ..lokking forward to the test flight ..but its snowing outside and aprox 0,5 meters snow !
Are there any that have build the plane with a YS that can give me a tip on the CG ...thinking on do i need to move radio equiment forward or backwards?
ID:	628740   Click image for larger version
ID:	628741   Click image for larger version
ID:	628742   Click image for larger version
