RCU Forums - View Single Post - Tower Trainer combo questions
Old 02-24-2007 | 06:27 PM
shd3920
Default RE: Tower Trainer combo questions
I've got a O.S .40 in mine, personally I wouldn't go lower than that. Although the minimum is .35 I was told it is always best to at least get the size in the middle range of the recommended scale, but if you must use the .35 it certainly can - but the power will be that much more limited.
Sig Kadet Senior trainer http://www2.towerhobbies.com/cgi-bin...?&I=LXFF89&P=7 would be a perfect candidate for your O.S .35 and a real great build if you don't mind building your plane.
