RCU Forums - View Single Post - Foam between wing and fuse
Old 02-10-2003 | 08:20 PM
hilleyja
Default Foam between wing and fuse
The foam also tends to provide a good tight fit which is important for wings with dowels on the leading edge. If a wing sits on the mount loose it will wear the mounting holes the dowels insert into.
