RCU Forums - View Single Post - Gas engine vibration precaution
Old 02-25-2007 | 11:49 AM
Antique's Avatar
Antique
Default RE: Gas engine vibration precaution
Re Loctite...There are many myths concerning strengths and colors...The different grades are different colors, but green 680 is the strongest..If you put green 680 on the brass screw that holds the throttle plate on the shaft and try to remove it, the screw will twist off before it unscrews...
The best way to find out about Loctite is THEIR website, certainly not here...
