RCU Forums - View Single Post - Engine Thrust Line
Old 02-25-2007 | 12:23 PM
hamishrock's Avatar
hamishrock
Default RE: Engine Thrust Line
Thanks for the help, I am a way off flying yet, but as you say I can try it, and then add any shims should I need too. The plan instructions suggest bolting the stab on and adjusting the flight using that.
I am not happy adding nuts and bolts that far backwards of the C of G, so intend to fix the stab at 0 degrees, and add the shims as sugested or simply add elevator trim, or maybe adjust the 6 ailerons.
