RE: Jack Stafford Chipmunk
I have the panel lines down on the fuse and the primer sprayed on. I will let that cure until tomorrow evening and sand the primer down to the chart tape then remove the taqpe to reveal the panel lines. I will be laying out the panel lines on the wing tonight and I will spray the primer tomorrow. It takes 5 coats of primer to build up the surface for the panel lines.
Anthony
