RCU Forums - View Single Post - SIMULATOR ADVICE
Old 02-25-2007 | 07:43 PM
Foxito
Default RE: SIMULATOR ADVICE
First of all, let me ask you this.....Do you have a Walkera heli and/or controller just like mine?
Because I don't know this, you haven't said it. - My controller is the one that comes with the Walkera Dragonfly 22E 3D 6-channel latest model 2007..... it has a 10 positions DIP switch in the back. From what I've learned on my researches, it seems like the 4-channel Walkera 22E has 8 positions, mine has 10.
Is this the same TX controller you have? - Because if it is the same as mine, then what you're doing there should work for me too.
Yes, I know that cable you told me about is for audio, it is very obvious to me, I'm an Electronics tech, btw. - Anyway, I still would like to try the way this cable came from Walkera rather than modify anything to use it the audio way.
I still don't know what exactly CCPM means, even though I've read it a million times, but I'm sure my heli has that CCPM stuff.....either way, what I meant is that I didn't know that point there in the back of the controller would have audio signals......but after all, it's true....if you would ever connect a digital signal to an audio amplifier, you would hear some sort of noise, and that's signal anyway.... So those flight simulator programs decode that signal via audio (not digitally as it should be) and make the thing work...interesting....hehe.
Yes, I have tried that PPJoy and PPJoyCom and no luck.......the best I had was that seemed like the signal was either inverted, or the wrong type of siganal....even the FMS program has a serial port tester that I tried and I don't remember now what it said or happened, but didn't work right either.
That's okay, I will get in touch with Walkera tech support tomorrow via e-mail and ask them. They were in holidays since last week until tomorrow, because this week has been the Lunar New Year, which is the new year holidays for Chinese people, and as you know Walkera is in Hong Kong.
Regards
