RE: problem with rush evo
There are many things that can be wrong. I would first check the mesh of the clutch bell and spur gear, because the spur gear might be stripped/worn out. If thats not the problem then take out your engine. Open up the clutch bell and check the clutch shoes if they are worn out. Other than that you might want to check the driveterrein and take apart the gears in the gear box.
