ORIGINAL: Fastsky
One issue is the reciever is matched to the transmitter, rather than to a channel so you won't be able to use the radio with any standard receivers that you may al lready have. I am not sure what you have to do if you want to get more recievers if you have more than one plane. The mounting is also a bit more involved because the setup actually uses 2 recievers in the plane.[8D]
They don't all take more involved mounting or have 2 separate RX
http://www.towerhobbies.com/rcwnews/...-futk6900.html
