RCU Forums - View Single Post - Wave jumping problem
Old 02-25-2007 | 11:31 PM
Wheelnut's Avatar
Wheelnut
My Feedback: (81)
Default RE: Wave jumping problem
its called cavatation. there is no way to fix the problem unless maybe if you convert it to surface drive. But that hull might not like surface drive. What is happening is when your boat jumps some air gets in the spinning prop and causes cavatation and when you let off the throttle the air goes up and then you hit the throttle again and the prop catches water.
