Flipping the Grips - Good or Bad?
You gotta read the article and then you'll see Benarios point.
Not all Raptors had the problem
however the problem occurs mainly with plastic grips and the method used to change blade pitch in flight. It doesn't occur on the R60 because of the change in design relative to how the blade pitch is changed.
