routing a antena in a tube ????
I use the "Hoover" method....
Insert a string into the tube.....attatch the hose off the shop vac
to the other end, turn on the vac....feed string through the tube...
Apply a dot of super glue to the end of antenna and stick to the string...let dry....pull string through the antenna tube...you're done''
Just a suggestion..
