RCU Forums - View Single Post - Ts Oxalys build
Old 02-26-2007 | 03:54 PM
Rune
Default RE: Ts Oxalys build
well made some fillers off balsa to get a good fit off the stab to the fuse, i think the tubes in the stabs are a bit wrong, needed 3 mm in front to get it rigth, the manual tells to press the fus to get it ok but dont like to stres the stabtube that runs through the fuse ,it maybe come loose if the press is to hard.
Also hinged the rudder up ...pretty straigth forward job!
