ORIGINAL: Gordon Mc
Search for Aeroloft throughout RCU and you will come across numerous other threads with people reporting the same kind of issue.
Gordon
Here you go Goosefly or whatever your other screen name is
ORIGINAL: Goosefly
I have used the Aeroloft transfers at least a dozen times. You need to use a heat gun to warm the surface just a bit ( maybe 5-7 seconds) and then use a beveled popsicle stick to transfer the decal. Use a piece of masking tape at the top of the transfer to make sure it does't move. I'm sure if you call Cindi she will take care of you 480-380-4779. Good luck Mike
[X(]
http://www.rcuniverse.com/forum/m_49...tm.htm#4950910
http://www.rcuniverse.com/forum/m_20...tm.htm#2038782
there are quite a few more threads by the way. I for one used to praise them and suggest everyone to use them until she pulled this stunt on me...
