RE: Welcome to Club SAITO !
Yes, it will not run correctly. I use a razor blade to hold the gear until the cover is all the way down, works every time. Seems to align the dot best when you hold the blade in your right hand (engine facing toward you), and I stick the gasket to the cam cover with oil first.
