RCU Forums - View Single Post - KMP Beaver
Thread: KMP Beaver
Old 02-26-2007 | 09:10 PM
Goldfinger41
Default RE: KMP Beaver
This Plane is not an ARF , It is a rework, redesign, kit , to be an ARF. I had to add on to the ailerons to eliminate the gap, the ailerons are the worst I have ever seen, Twisted and not straight. The fuselage is very thin , the cowl is thin, the floats are thin, I am going to reglass all of them. The rudder tailwheel servo tray is missing. The formers inside the fusealge are not straight, The ring for the cowl does not fit. The landing gear had to be busted lose and rewelded to fit in the slot correctly. The Incidence on the floats will have to be reworked. I am sure I will find some more when I get to it. This so called ARF is not worth the money .
A good example of an ARF with adequate and detailed instructions are
Hobbico, SIG , Great Planes , Kangke , Top Flite, Lanier , World Models .
