RE: Echo BME twin
Are you going to set it up so one cylinder will fire then the other or will they fire at the same time?
If they fire at the same time you are better off with a large single cylinder.
Larger bore means bigger ports that equals more power.
The advantage of twins is they run smoother and sound really cool.
