RE: Walbro Carb question
Glad you have fire. Try what Silversurfer suggests before you take the engine out. Probably a very simple fix. Again look for any possible crack or break in the intake and fuel system and make sure all 4 bolts for the carb and intake are tight. The two for the intake manifold block are under the carb so you need to remove the carb to get to them.
