RE: Hangar-9 Sopwith Camel Build Thread
OK, after all the good advice on this thread about weight and balance, I did some numbers and saw I was heading for a pig. I am now working to move things forward to avoid adding too much ballast. Boy is this thing sensitive to CG!!
I had to cut the firewall to get the battery forward, and most electronics will go under the cowl (except the Rx). I am posting a little Excel sheet to share my weight and balance. I hope it may be useful for other folks to plan their radio, motor, and equipment install. For us electric guys, the lighter motor seems to create a balance challenge.
I will post pictures of the final installation when it is done.
PS Just change the *.txt filename to *.csv for Excel to read it.
