RE: Echo BME twin
I got my block today and should have the donor motors by Wed. Tim, did Keith give you a number for the third bearing? Also do the other two come from the donors or do I need to get something ordered up? Looking at this little block I may be inspired to build a 100. It would be a bit of work to whittle out a block manually but it could be done. I need to look around for some suitable donor engines. Are there any current 50cc reed valve industrial engines?
Mark
