RE: What Prop for Big Stik 60?
If you use a Master Air Screw make sure you take the time to balance it. Only thing I don't care for on that mfg. is how bad the balance is. APC props are pretty close off the rack and can get by if not able to balance. Make sure on any new prop you use take the time to sand the sharp edges. They can cut like a razor blade. Most of the sizes that you mentioned are ok. For power go with a long prop with little pitch.
